Hello
Guest
it is
December 21, 2024, 11:55:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
DRO
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: DRO (Read 3852 times)
dhaxt
8
DRO
on:
July 20, 2007, 02:31:57 PM »
Whenever i start Mach i get readings on the DRO's and have to zero them before starting. Is this normal? Oh and by the way complete newbe here need lots of help. Also how would i go about posting a screen shot of what i am talking about?
Logged
Re: DRO
Reply #1 on:
July 20, 2007, 07:11:43 PM »
You can set it up to read zero at each start of mach. However the usual procedure is when you start you should reference your machine (if you have limit switches) That way Mach knows where the table is and this will allow you to also use soft limits.
Once you have referenced the machine if you press the "machine Coords" button you will see all 0000's but when you press it again you will see the last saved offset, that is if you have that option checked.
Do you have limit switches on your machine??
Logged
dhaxt
8
Re: DRO
Reply #2 on:
July 20, 2007, 10:11:05 PM »
No limit switchs installed yet. I do have them just need to get them installed. Thanks.
Logged
Chip
2,055
Gainesville Florida USA
Re: DRO
Reply #3 on:
July 21, 2007, 11:51:19 AM »
Hi, Dhaxt
In Config, General Config..., Un-check the "Persistent DRO's" Box, Bottom Right of Screen.
That should fix it, Shut down Re- start Mach.
Hope this Helps, Chip
Logged
dhaxt
8
Re: DRO
Reply #4 on:
July 21, 2007, 02:17:47 PM »
Unchecked persistent DRO's box. That fixed it. Thanks guys. Limit and home switchs next.
Logged
Print
Pages:
1
Go Up
« previous
next »
