Hello Guest it is December 22, 2024, 01:11:44 AM
Author Topic: Can't jog more than 1 axis at the same time.  (Read 7865 times)
Re: Can't jog more than 1 axis at the same time.
« Reply #10 on: July 06, 2018, 07:29:45 PM »
well I stand corrected.
I use a pendant for that sort activity and that is certainly one axis at a time.  When I'm trying to touch off or otherwise position
a part my preference is one axis at a time anyway.
Its not that I can't multitask...I can....I can talk AND piss you off at the same time! LOL
« Last Edit: July 06, 2018, 07:31:19 PM by joeaverage »
« Reply #11 on: July 06, 2018, 09:25:32 PM »
I know it would be a "stretch" from your home location so maybe off is better than on. LOL  :D
Back to the sidelines...........
« Reply #12 on: July 06, 2018, 09:59:56 PM »
Hi Rich,
I think you underestimate my 'pissoffing' talents, why you are only 8000 nautical miles away....a mere snap!LOL
« Reply #13 on: July 13, 2018, 09:27:51 AM »
HI!
I have the same problem with chinese USB board...
any solution?
Doug
« Reply #14 on: August 16, 2018, 11:38:16 AM »
That happened to me several years ago, but I don't remember how I fixed it (I guest from now on I will start to write notes)... Yesterday after I've installed the new Galil Plugin Version 1.6 it was fine until I powered the machine up today which now I can only jog one axis at the time via keyboard Arrows and Page-Up/Down.
I run Galil DMC-21x3 Ethernet and Mach3 with Allen Bradley Ultra-100 servo amps. Any help will be appreciated!
Luiz
« Reply #15 on: August 16, 2018, 03:33:20 PM »
Last post I should've wrote Galil 4.6 plugin instead of "1.6"... Going back to the 4.5 plugin solved the problem!
Thanks, Luiz
