Hi Tweakie.CNC ,
I think everything in this world is financially driven - if you were a potentially enormous customer then the software would, I am sure, be changed to suit your machine and your requirements. However, in reality, we have to learn to adapt our machine's and their set-up's to suit the software that is currently available and if you choose Mach4 then Craig has made some excellent suggestions to achieve a compromise solution to your exact stop issue.
As I mentioned earlier Mach4 is under development and if enough users need it, the cycle stop function may well be modified in the future.
I'm writing a message through Google translation, maybe I do not understand you correctly, and you, too, me.
It's right that Mach4 does not want to change for one buyer, just like the seller does not want to change the machine for one Mach4.
Which car the buyer chooses, I do this for the buyer. If the mach4 will be more ordered, I will buy more mach4.
Now mach3 choose more buyers than mach4.
I wrote why I will not change the settings of the servos. Most importantly, these settings work with other controllers and do not work with mach.
The greater the speed and acceleration of the laser cutting machine, the higher the servo settings must be for high cut quality.
This is not the main problem. I will delete this button. I asked if there is a solution.
I wrote two more problems that arise when moving.
