Hello Guest it is October 05, 2026, 04:07:21 AM
Author Topic: Loading GCode is very slow  (Read 5570 times)
« on: August 16, 2018, 03:56:33 AM »
Hi
I run several PCs with Mach3 and one of them is very slow at loading gcode. A 1000 lines gcode file takes a few minutes to load, the other machines do it in <1sec (same PC model, Win10, i5, 6GB memory)
Are there any settings which can cause this? A big problem is that the machine is inside a cleanroom without network connection so 'just try something' will take about half an hour  :)
Any help would be appreciated.
