Hello
Guest
it is
March 14, 2025, 01:46:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cycle start button on panel?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cycle start button on panel? (Read 3452 times)
stevehuck
425
on:
December 23, 2018, 06:24:56 PM »
I tried to search the forum but the search funtion is broken.
I would like to add an E-stop and cycle start button to the control panel on my lathe. The E-stop seems easy but the cycle start isn't as clear. I found this in the Mach3 docs.
Enable and define OEM Trigger inputs if you want electrical signals to be able to call OEM
button functions without a screen button needing to be provided.
I assume i would use one of these inputs? I can wire the buttons and configure the inputs but I cant find a way to define the chosen OEM input to trigger a Funtion "0" or cycle start.
Am I on the right track? There is no further info in the docs about OEM inputs. Is a Cycle start button possible?
Logged
stevehuck
425
Re: Cycle start button on panel?
Reply #1 on:
December 23, 2018, 06:30:35 PM »
Found it!
It's in the system hotkeys setup. I have some testing to do.
Logged
davidruizv@gmail.com
1
Reply #2 on:
July 11, 2019, 01:58:12 PM »
Hola seƱores, alguien ha podido conectar y configurar bien los finales de carrera de esta tarjeta???, por favor ayuda. gracias.
Logged
Print
Pages:
1
Go Up
« previous
next »
