Sounds to me like you just need to set the spindle lever up as your Z axis. pop a stepper and a belt drive on it and configure Mach3 to run with the MPG you have, and you should be good. With this said I think you'd be better off programming a drilling cycle for what you need doing, it will be more consistent, quicker and safer.
