Hello
Guest
it is
October 06, 2024, 07:50:45 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
DQ542MA
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: DQ542MA (Read 6343 times)
schalkvdwesthuizen@gmail.
18
Re: DQ542MA
Reply #20 on:
February 11, 2019, 01:37:59 PM »
I have changed the DQ542MA to 800pulses
Its a nema 23. 1.8° 200steps
Logged
TPS
2,528
Re: DQ542MA
Reply #21 on:
February 11, 2019, 01:46:07 PM »
and the Motor current?
Logged
18
Re: DQ542MA
Reply #22 on:
February 11, 2019, 02:27:24 PM »
Current is still the same. If i make it less the motor wont turn at all
Logged
TPS
2,528
Re: DQ542MA
Reply #23 on:
February 13, 2019, 01:45:27 AM »
sorry for the delay,
maybe you can post a photo of the Motor Connections at the DQ542MA and at the HY-Div 268N ?
Logged
18
Re: DQ542MA
Reply #24 on:
February 13, 2019, 02:10:27 AM »
Hi.
I have read that it can mayne have something to do with the ACPI drivers ?
Logged
TPS
2,528
Re: DQ542MA
Reply #25 on:
February 13, 2019, 04:41:48 AM »
why should it be something with the ACOI Drivers,
when your y-axis Controller is running on the x-axis Outputs of the BOB,
and only the new x-axis Driver is not working ?
Logged
18
Re: DQ542MA
Reply #26 on:
February 13, 2019, 05:46:49 AM »
Dont know what to do anymore. At the point to mayne rebuilt with Arduino and use a diffrent platform than Mach3
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
