Hello Guest it is December 21, 2024, 10:41:14 AM
Author Topic: MDI does not respond  (Read 13189 times)
Re: MDI does not respond
« Reply #10 on: August 15, 2007, 05:21:51 PM »
Can you post a screenshot here so we can look. Sounds like you may be missing some of the bitmaps or the screen set you have is corrupt, you could try installing mach again to see if that clears it up.
Sorry, I couldn't get it through this way, may be if you submit an e-mail to send you the print screen.
Any way I'm going to reload the program.
         Jovimon
« Reply #11 on: August 15, 2007, 05:24:26 PM »
Have sent you an email.
« Reply #12 on: August 15, 2007, 06:12:55 PM »
I sent the screenshot to the engineering address.
I reloaded the software again from (Mach3 R2.4.0 (Click Here)  -->  (Release LockDown), and I got the same thing (No Reset Buttom anywhere). May be I’m downloading the wrong version?
     Jovimon
« Last Edit: August 15, 2007, 06:36:42 PM by jovimon »
« Reply #13 on: August 15, 2007, 06:26:18 PM »
I have sent you an email, so you can just reply to it with the screenshot attached.
« Reply #14 on: August 15, 2007, 06:37:39 PM »
Ok, I already did it to the engineering address. Sorry
« Reply #15 on: August 15, 2007, 06:47:02 PM »
I Checked your "precisionchaos" web page, I see you do a great job.
Thanks Jovimon,
    Watch the welcome tutor, will help with attachments.
http://precisionchaos1.com/welcome_tutor_flash/welcome_tutor_flash.html
I have inserted a screen shot of the button you are looking for. If this button is now where on your screens, you might want to back up your XML and any screensets or grabber profiles you have, uninstall Mach, delete the mach3 folder on your c drive, download and reinatall Mach again.
« Reply #16 on: August 15, 2007, 06:57:30 PM »
Not got your email :(
« Reply #17 on: August 15, 2007, 11:37:17 PM »
Thanks Jovimon,
I uninstalled Mach and followed all your instructions you suggested, but no change at all. Here I'm including the screenshot in word (doc) of what I'm getting on screen (no Reset Buttom). Shoudl I check the XP optimisation instructions ?.
« Reply #18 on: August 16, 2007, 07:26:03 AM »
OK Jovimon, That helps a lot. A picture is worth a thousand words. THe problem is this, your not seeing all of your screen. Go to general config and check the box Auto Screen Enlarge, Its down at the bottom, center right. You may have to exit mach and re-open for this to take effect. You may need to play with other settings in Screen control, I don't think so though. Give it a go and let us know. If, when you open general cofig. the bottom it it is missing too, grap it at the top and slide it up so you can get to Screen control.
« Reply #19 on: August 16, 2007, 07:32:18 AM »
Also, check out this link. It is a free screen capture program. It is very easy to use and you can save your shots as jpeg and other formats.
http://wisdom-soft.com/products/screenhunter.htm
