Hello Guest it is September 20, 2026, 04:32:30 PM
Author Topic: StepCraft inlcuding a WinPC-NC USB-Module  (Read 27268 times)
Re: StepCraft inlcuding a WinPC-NC USB-Module
« Reply #10 on: April 17, 2019, 02:24:52 AM »
Is it a good idea if I buy the 13€ Parallel Module (LPT1) and a PCI express DB25 parallel card and LPT cable? would it then work?
Yes, cheap and cheerful. Once upon a time ALL Mach3 was run that way.
Be sure you have 32 bit Windows 7 or XP, the parallel port WILL NOT work on 64 bit, laptops or Windows8 or later.
Best idea is do a fresh OS install and only have enough software just to run Mach and no more. No internet. No anti-virus.
No updates. No nothing....Mach and Mach alone.
« Reply #11 on: April 17, 2019, 07:47:46 AM »
I don't have Windows 7 or XP license. Does Mach3 work on Linux? Or anyway I can get it to work on Windows 10?
« Reply #12 on: April 17, 2019, 08:01:53 AM »
Yes, it will work in Windows 10. Get a UC100, like most Stepcraft machines use, and plug it into the parallel interface card.
https://www.stepcraft.us/shop/product/10100-parallel-module-15?category=5
« Last Edit: April 17, 2019, 08:10:49 AM by ger21 »
Offline reuelt
  •  520 520
« Reply #13 on: April 17, 2019, 08:04:50 AM »
Stepcraft claims their machine at run at max. speed of 50mm/sec=3,000mm/min.
To achieve that Max. Speed, the Windows 7 32bits PC running MACH3 will need at least a CORE-2-Duo 3GHz CPU and running MACH3 kernel speed at 45,000Hz.
I upgraded my old PC from core-2-duo 2.4Ghz (max speed was 1800mm/sec) to Core-2-Duo 3.0Ghz for AUD$9 from ebay and max speed went up to 3,000mm/min and I could surf the INTERNET while machining with no issue.
I also have a new PC with I5 7600 9 3.6GHZ (4cores) and I could reach 4,000/mm with no problems even though my motors are still at 24volts.
BUY a 2nd hand Windows 7 32bits PC. They should be cheap and readily available for below 150 EUROs
« Last Edit: April 17, 2019, 08:08:21 AM by reuelt »
"the gift of God is eternal life through Jesus Christ our Lord"
