Hello
Guest
it is
July 27, 2024, 11:52:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
My stepcraft DL445 laser leaves a path
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: My stepcraft DL445 laser leaves a path (Read 5313 times)
TPS
2,510
Re: My stepcraft DL445 laser leaves a path
Reply #20 on:
June 13, 2019, 02:03:59 PM »
well, walked through the stepcraft Manual, not getting 100% clever, but here a "try"
pls try also Output1 Active Low Setting.
Last Edit: June 13, 2019, 02:05:31 PM by TPS
Logged
Chank Hervella
14
Reply #21 on:
June 13, 2019, 04:04:34 PM »
Same thing my friend, I tried with active low off in output1 after I tried on and nothing new happened, thanks for your time
Logged
TPS
2,510
Reply #22 on:
June 13, 2019, 11:59:02 PM »
i will try to contact stepcraft to get more information
Logged
Chank Hervella
14
Reply #23 on:
June 14, 2019, 03:42:08 AM »
thanks, i tried a couple times and they said "we dont have technical service support to mach3"
Logged
TPS
2,510
Reply #24 on:
June 14, 2019, 09:14:31 AM »
next try.
Logged
TPS
2,510
Reply #25 on:
June 14, 2019, 09:25:47 AM »
got some more documentation about Pins of laser Interface.
and sorry, i was wrong in an earlier reply M11P1 means Switch Output 1 ON
Logged
Chank Hervella
14
Reply #26 on:
June 14, 2019, 11:50:43 AM »
i tried with the last file, laser never on, i activate low in output 1 and the laser never off, i bought a UCCNC
now i need to configurate
Logged
TPS
2,510
Reply #27 on:
June 14, 2019, 02:55:38 PM »
OK, one eye is a Little bit sad to hear, that you gave up, but only one eye.
Logged
Chank Hervella
14
Reply #28 on:
June 14, 2019, 04:43:08 PM »
Everything is perfect with UCCNC, my machine was created to use with this software, that the reason doesn't works perfectly witc Mach3, thanks to all the people who helped me, this is the best Mach3 blog ever!
Logged
Tweakie.CNC
9,214
Super Kitty
Reply #29 on:
June 15, 2019, 01:33:22 AM »
I am pleased to hear that you now have your machine working as it should - your latest engraving picture looks excellent, good fortune with your future laser adventures.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
