Hello Guest it is March 13, 2025, 06:41:44 PM
Author Topic: Problem with Probe signal from Brain  (Read 13510 times)
Offline MN300
  •  306 306
Re: Problem with Probe signal from Brain
« Reply #10 on: July 03, 2019, 12:49:14 PM »
The other side of both switches go to ground.
The NC switch normally shunts the current from R1 to ground. When the switch operates R1 is released to turn on the transistor, pulling the output to ground.
The NO switch directly pulls the output to ground.
