Hello Guest it is December 22, 2024, 12:54:23 AM
Author Topic: Which 3d image software?  (Read 3255 times)
« on: July 02, 2019, 08:26:09 AM »
Hi everyone, i am very much a newbie to the cnc world. i have my 3040, am about to purchase mach 3 and need advise on which software (hopefully free) for creating 3d images is the best please.
Many Thanks
Dale
Re: Which 3d image software?
« Reply #1 on: July 02, 2019, 08:43:15 AM »
Fusion 360, made by Autodesk, the same company that makes AutoCAD, Inventor and HSMWorks, has made a splash
because its free to hobbyists. It is by no means the only CAD/CAM program around but it is a good one.
Often you have a very simple job for which you don't require CAD/CAM, maybe cut a rectangular slot, drill a bolt pattern
and face the material. NFS MillWizard ($75) is good for chaining simple operations together. It gives what amounts to
'conversational programming' to Mach. I use it a lot.
« Reply #2 on: July 02, 2019, 09:49:59 AM »
Thanks Craig
« Reply #3 on: July 02, 2019, 11:36:39 AM »
"3d IMAGE"  is most likely the wrong terminology. Images are not 3D.
Can you post an example pic of what you want to do? I suspect Fusion 360 would not be the best option.
« Reply #4 on: July 03, 2019, 08:28:10 AM »
This eventually
« Reply #5 on: July 03, 2019, 11:30:24 AM »
That's just a 2D image? What do you want the finished project to look like?
You'd likely want to use something like Aspire to create a 3D model of that. Be aware it will take a lot of skill, practice, or both.
« Reply #6 on: July 09, 2019, 05:49:06 AM »
« Reply #7 on: September 25, 2019, 03:18:44 PM »
Vectric Aspire is what I use. Pretty simple, great tutorials, good support(overseas). I am 1 year new to this and feeling very comfortable with the software and creating 3D finished products from 2D vectors and images. A little late on this but my .02 in case it helps someone else.
