Hello Guest it is March 31, 2025, 08:12:46 PM
Author Topic: Automatic Turret Tool Head-Mach3  (Read 12829 times)
« on: August 23, 2019, 04:01:39 AM »
We would like to introduce you a new gadget to increase the productivity of machining for all who want to improve the classic, or CNC-converted lathe. Our Automatic Turret Tool Head enables quick change of up to eight tools while maintaining high repeatable accuracy. This is maintained due to the high rigidity of the patented pneumatic mechanism.
The turret head is designed for use on CNC lathes running Mach3 software. You need to remove original tool holder. The head can then be mounted on the slide, you just need to connect pressurized air, connect 5 wires to the control electronics, adjust a few parameters in the program, download the control macro and start machining.
For conventional lathes, an increased number and fixed tool positions in combination with digital axes can also be used to speed up machining. In manual mode, rotation is triggered by a button on the solenoid valve.
Furthermore, it is possible to supply coolant directly to the cutting edge of the tool by means of the special plates. Primarily it is possible to clamp a 12x12 mm tool on the head. For other tools of different shapes (drills, mini chucks, milling cutters...) it is necessary to make an individual accesories according to the attached drawing. The turret head can be mounted even on smaller lathes, for mounting it is necessary to make or otherwise obtain a base plate, which must be attached to a specific support with screw holes for the turret head as shown in another drawing included in manual.
Price without VAT is 769  USD, outside EU
Price include VAT is € 849, in EU
More info and videos at: https://www.altaros.cz/turret-head
Contact: atc@altaros.cz
« Last Edit: August 23, 2019, 04:08:42 AM by Altaros »
Re: Automatic Turret Tool Head-Mach3
« Reply #1 on: August 23, 2019, 09:37:55 AM »
This link should work, if the original is not working.
https://www.altaros.cz/en/content/53-automatic-turret-head
TECHNICAL DATA:
Recommended pressure 58-60 PSI / 4-4.2 bar, MAX 72 PSI / 5 bar
Voltage DC 12 V
Recommended cutting force 500 N, MAX 650 N
Turret head dimensions:
« Last Edit: August 23, 2019, 09:49:31 AM by Altaros »
« Reply #2 on: April 02, 2020, 04:16:18 PM »
Has anyone purchased one of these that can give some first-hand feedback?  I'm considering getting one, but I am hesitant since I can't find any reviews at all on line.
Thanks!
« Reply #3 on: April 03, 2020, 05:46:28 AM »
Hello, we have sold this product in our Czech Republic and others in Japan and Norway. According to our experience with other products, if the product serves well, people do not feel the need to write reviews. Most people write something if they have a negative experience. One review is on the forum in our country (link below), you can use the translator. One user is trying to control this turret head with the Linux system.
Link here: https://forum.strojirenstvi.cz/viewtopic.php?t=32601&hilit=altaros
