Hello Guest it is October 10, 2026, 02:34:47 PM
Author Topic: cant slave axis Y-A in STB 5100  (Read 32898 times)
« on: October 26, 2019, 05:06:17 AM »
Hi ,
    i have installed STB5100 5 axis motion card with mach3 , i configured slave axis A with Y as master-slave is not responding to Master Y.Can anyone help me?
Re: cant slave axis Y-A in STB 5100
« Reply #1 on: February 14, 2020, 08:44:02 PM »
Hi my friend, did you find a solution? I am facing the same problem with this breakout board stb5100...
« Reply #2 on: October 03, 2020, 06:49:12 PM »
Whilst this is an old topic, I'm replying in the hope that future searches prove fruitful.
I have had success syncing the A and Y axis by using the attached diagram.
Note that the Orange and Red wires for A axis are joined to the Y axis in a 'piggy back' fashion rather than running a slave.
I suspect this will work regardless of the driver board you're using.
