Hello Guest it is September 15, 2026, 08:14:31 PM
Author Topic: Push Start and stop button  (Read 7175 times)
« on: December 04, 2019, 11:45:14 AM »
Hello, please help and advice.  I'm installing a push button to start and push button stop the program, (rather than clicking a mouse or the key board). I'm using a PLC unit to be the slave to mach3. Is there a way that the Mach3 system can to send a signal to the plc, notifying that machine is at X0,Y0,Z0, ie. Home position and is ready to start running the program?
thank you in advance.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Push Start and stop button
« Reply #1 on: December 04, 2019, 06:50:50 PM »
You need to read up on MODBUS assuming your PLC has that function
