Hello Guest it is March 31, 2025, 08:16:22 PM
Author Topic: Practice Part  (Read 10222 times)
Practice Part
« on: December 09, 2019, 02:36:41 PM »
2x4x2" PVC. 9 Tools 10 Operations. All tools preset in control.
Pictures Attached
  •  9,284 9,284
Re: Practice Part
« Reply #1 on: December 10, 2019, 01:48:08 AM »
Excellent work.
Just one point, it's probably the camera angle, but that chamfer does not look concentric.
Re: Practice Part
« Reply #2 on: December 10, 2019, 09:01:56 AM »
Tweakie,
You're very observant :) Not sure what happened there. All of the other chamfers look great. My guess would be that the drilled hole is slightly off center. I did a small spot drill followed directly by a 1/2" drill. The spot drill may have never centered the bigger drill up.
It doesn't look quite as bad from other angles. You can sure count on your chamfers to tell you where you screwed up!
Re: Practice Part
« Reply #3 on: December 10, 2019, 09:03:51 AM »
Picture Attached
  •  9,284 9,284
Re: Practice Part
« Reply #4 on: December 10, 2019, 10:03:03 AM »
I think you are right, it looks like drill drift when viewed from the top.
If everything of mine turned out as good as that I would be well pleased - keep up the good work my friend.
Re: Practice Part
« Reply #5 on: December 10, 2019, 09:12:18 PM »
Thanks  ;D
