Hello Guest it is December 21, 2024, 11:03:42 AM
Author Topic: "Reference All" Jitters in Motors (M3)  (Read 4024 times)
Re: "Reference All" Jitters in Motors (M3)
« Reply #10 on: January 12, 2020, 08:14:56 PM »
open vbscript Editor, Mainmenue    Operator -> VB Script Editor
then copy/paste this code into the Editor
Code: [Select]
DoButton( 24 )
While IsMoving
Wend
code"(Z Axis is Referenced)"
code"G4 P.1"
DoButton( 22 )
While IsMoving
Wend
code"(X Axis is Referenced)"
code"G4 P.1"
RefCombination ( 10 )
While IsMoving
Wend
code"(Y Axis is Referenced)"
code"G4 P.1"
While IsMoving
Wend
If(GetOEMLED(23)=false) Then 'This will turn on the softlimits on
  DoOEMButton(119)
End If
While IsMoving
Wend
code"(All Axis are Referenced)"
While IsMoving
Wend
code"G4 P.1"
While IsMoving
Wend
Code"(Moving to Home Position)"
Code"G28"
While IsMoving
Wend
DoButton(7)
While IsMoving
Wend
Code"G4 P.1"
While IsMoving
Wend
Code"(X and Y axis are Homed and Zeroed)"
use the >|| button (Step Into Script) to run code line by line and see where the jitter happens.
BTW, do you have any values in
Config -> Homing/Limits -> Home Off. ?
OK will give it a go and report back and let you know about those values.
