Hello
Guest
it is
September 08, 2026, 08:08:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Feedrate over problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feedrate over problem (Read 8590 times)
yercik
on:
September 17, 2007, 12:43:44 AM »
There is a bug with the FRO. When I change the FRO value (Ex: %150), the feedrate increases (not limited to maximum axis speed).
Logged
Chaoticone
5,624
Precision Chaos
Re: Feedrate over problem
Reply #1 on:
September 17, 2007, 05:58:32 AM »
Have you tried to check the No FRO on Queue check box in general config. to see if that helps?
Logged
If you could see the things I have in my head, you would be laughing too.
Print
Pages:
1
Go Up
« previous
next »
