Sorry my fault.
code corrected:
If GetOemLED(821) Then 'Bar end signal
Code "G0 G54 Z110"
ResetOutBit(90,11) 'Collet close reset
SetOutBit(90,9) 'Collet Open
SetOutBit(90,6) 'Collet Open
SetUserLed(1001,1) 'Set Collet open LED ON
While Not(GetInBit(91,1)) 'Wait for Start signal from Bar fedder
Sleep(100)
Wend
Code "G0 G54 Z-35"
Sleep 1000
If GetInBit(91,1) = 0 Then 'Wait for Start signal from Bar fedder
Sleep(100)
End If
ResetOutBit(90,9) 'Reset Collet Open
ResetOutBit(90,6) 'Reset Collet Open
SetOutBit(90,11) 'Collet Close
Sleep 100
SetUserLed(1001,0) 'Set Collet open LED OFF
Sleep 2000
Else
sleep 100
Sleep(100)
Wend
sleep 100
Sleep 2000
End If
This one Works at least in VB script editor. I'll Test it on machine in few hours and let you know result.
Thank you
Well, this is working, but there must be no Sleep in middle of Whille and Wend. Like this:
Wend
But Unfortunately this didn't solve my problem. Still some times don't get input. Led on CSMIO controller illuminates, but looks like in program doesn't detect it. I also try different inputs, but always the same result.
It really is frustrating. Whole retrofit end up terrific, machine is working great, but without bar feeder is useless.
Do you have any clue what could be the cause of that problem?
