Hello Guest it is February 27, 2025, 08:48:49 PM
Author Topic: Ref All Home and Go to Zero  (Read 4621 times)
« on: April 05, 2020, 10:58:22 PM »
I have limit switches working, and a separate homing switch for Home.
I can click "Go to Zero" from anywhere and it goes back to home (zero)
But, when I push "Ref All Home" the Y-axis motors don't work together, it's hard to tell if they are either not moving the same speed or if one is not working.
Everything else works as it should but homing freaks out the machine and I have to hit the E-Stop.
Any Ideas?
Joel
Re: Ref All Home and Go to Zero
« Reply #1 on: April 08, 2020, 02:56:40 PM »
Joel,
I think you are confused between the terms Machine Zero ("Home" position) and Part/Program Zero (lower left hand corner of your work piece - wood). It's not your fault, the 'Go to Zero' button should be labeled 'Go to Part Zero'.
The 'Go to Zero' button in Mach 3 is used to move your router from the Home position  to the lower left hand corner of your work piece. In other words, once you establish the Home position (Machine Zero), you and Mach 3 can find any other X and Y position on your table. Just move your router (X, Y) to the lower left hand corner of your work piece, lower the Z-Axis to the top of your board, and then just zero out  the X, Y, and Z-Axis buttons in Mach3 (Main Screen).
Now, when you click the Go to Zero button, Mach 3 will automatically move your router from the Home position to your Part/Program location.
Try the following: Turn off your Homing switch in Mach 3 for this example.
1. Move your machine (tool bit) to a random location on your table and call it "Home" (Machine Zero). This is usually located somewhere near the lower left hand corner of your table. Mark the location with an X.
2. Raise the Z-Axis upwards and stop at a point (just before hitting the Limit Switch) you want to call Home for the Z-Axis.
3. In Mach 3, click the 'Ref all Home' button (all zeros). You have now established the Home position for the X, Y, and Z-Axes. (Remember to Save your settings before closing out of Mach 3.)
4. Now, starting at the Home position, move the router to the lower left hand corner of your work piece. Lower the Z-Axis to the top of your piece of wood. Go to the main screen in Mach 3 and "zero" out the X, Y, and Z-Axes.
5. Return to the Home Position by entering G91 G28 Z0 (one line) in the text box (MDI screen in Mach 3) and hit the Enter key on your keyboard.
6 Finally, to verify that you set it up correctly, hit the Go to Zero button in Mach 3. Your tool bit should be sitting on the top of your work piece (lower left hand corner).
« Reply #2 on: April 08, 2020, 06:57:52 PM »
Rsecura,
Thank you for spending some time to help me out. I decided to leave the machine alone for a couple of days and now I'm refreshed and ready.
I want to document this so that people in the future can see a solution.
1. I didn't have the Home switch on "A". I had Home on Y and that was fine but I also unclicked "Home Slave axis with master". This told one motor to run and the other wasn't. This is why the table freaked out and I had to hit E-Stop.
2. I switched the X and Y limit switches when I rewired. When I double-checked everything I noticed that the Y-axis didn't stop when I activated the Limit switch for Y. I feel dumb, but mistakes are mistakes.
Everything is working as it should.
Joel
