Hello Guest it is December 21, 2024, 10:06:56 AM
Author Topic: windows  (Read 1705 times)
windows
« on: May 06, 2020, 07:51:28 PM »
computer crashed, gotta buy new one, or refurb, running windows 7 Hp,, my questions is what windows version should i look for. ive heard of problems with 10  how about windows xp professional??  if i need 7 hp ill look until i find it,,only experience with this was i found out windows 8 sucked  bty, im using parralell port
Re: windows
« Reply #1 on: May 06, 2020, 08:12:14 PM »
if you wish to continue with a parallel port then you MUST use 32 bit Windows 7 or earlier. XP Pro would be fine if it 32 bit?
Machs parallel port will not operate with ANY 64 bit OS.
If you wish to use a 64 bit OS, or Windows 10 (which works perfectly well by the way), or a laptop the you need an external motion
controller like an Ethernet SmoothStepper or a UC300.
Re: windows
« Reply #2 on: May 06, 2020, 08:34:55 PM »
i dont see my answer but was trying to thanks you
larry
Re: windows
« Reply #3 on: May 06, 2020, 11:01:48 PM »
its simple:
Parallel port = Windows 7 or XP, must be 32 bit
External Motion controller = Any Windows OS, either 32 bit or 64 bit, and Laptops
