Is it possible to turn off "Reset plane on regen", I tried unchecking the "reset plane on regen" but it must do something else.
Also is it possible to show the tool in the toolpath window (pretty much the same as it used to be).
Because I'm using a mill I'd rather not use the side tool, which seems more for a routers use, I also like the way when the spindle was spinning the 3d tool would spin.
