I'm bringing up my milling machine after replacing the WinXP PC with a Win10 one and SmoothStepper. I thought I had everything dialed in, so I ran a program (admittedly a new one I'd never run before), and it stopped mysteriously about 85% of the way through (line 4990 out of 5660). I can't figure out why. I've attached a screenshot of Mach 3 showing the line it stopped on, a copy of the G code (generated by Cut2D from my drawing), and a photo of the part after the machine stopped (it was milling out that central pocket). Also, the spindle stopped gradually, like it was using Mach 3's deceleration parameter, not abruptly. Any ideas?
PS - I realize the cutout profile should have been cut last, but in my zeal to get the program running I didn't realize I saved it in the wrong order. The tabs held everything together just fine, though.
PPS - The uploader keeps telling me there's already an attachment with the same name as mine (even though they all have different names). I've tried uploading just a single attachment but it gives me the same error, so I'm afraid I can't upload any attachments. I've even tried uploading a single attachment as a reply to this post, to no avail. Any tips on what's causing THIS problem?
