Hello Guest it is March 25, 2026, 06:54:32 PM
Author Topic: Galil card 18-2 for 3 axis  (Read 7563 times)
« on: October 03, 2007, 08:57:44 AM »
Help
Got the new Mach 3 for my mill which has the Galil driver card for steppers 3 axis and apparently dont know how to set up the port. Totally frequently lost. The lady of the house said that was nothing new. Is there a place to go to to walk me thru the Mach 3 setup with the galil. Have camsoft on now and WORKED perfectly till I messed(screwed) with it.
racear
Re: Galil card 18-2 for 3 axis
« Reply #1 on: October 04, 2007, 08:51:47 AM »
Do you have your Old Camsoft setup files???  It would be nice if you could get it back up and working with the software that you had in the past... You could check the CBK file and use that to see what you were sending to the machine. Then you can go back and set the commands back to what you had when it was working :) Also if you post the file here there are a few of us here that should be able to help a bit with the Galil code.
thanks
Brian
www.newfangledsolutions.com
www.machsupport.com
