Hello Guest it is September 18, 2026, 05:05:54 AM
Author Topic: Hicon Integra 7866 to Gecko G201  (Read 14795 times)
« on: November 17, 2020, 09:07:26 PM »
I have purchased a used CNC machine with Gecko G201 drivers and want to use my Integra 7866 controller. After reviewing the knowledge base article showing sample wiring with Gecko G210 and G213V drivers I'm a bit unsure of the correct wiring. The G201 looks a little different so I wanted to verify the correct 7866 to G201 wiring.
I have attached the Gecko G201 manual.
Ken
Re: Hicon Integra 7866 to Gecko G201
« Reply #1 on: November 18, 2020, 08:05:14 AM »
Hello Ken
You can use the wiring of G210. Connect Dr- (direction-) and Sp- (step-) from the 7866 controller to the Gecko.  Connect +5V from the controller to the Common of the driver.
« Reply #2 on: November 18, 2020, 11:40:01 AM »
Thank you for the quick response! I will use the G210 wiring diagram.
Ken
