Hello Guest it is September 22, 2026, 08:14:12 PM
Author Topic: Best Way To Run My Machine  (Read 27284 times)
« on: November 26, 2020, 12:35:48 PM »
Hi, I'm new to cnc and Mach3and have been trying to set up a second hand machine i got from my uncle with no success.
My laptop is windows 10 64bit, will mach3 work with this???
it appears this laptop doesn't have the port that I have seen in videos online???
I have tried to get an older laptop with an older version of windows but to no avail so far, should i keep looking or is there a way to make it work by modifying the control panel???
Would mach 4 be a better choice for me??
Any help would be appreciated as I would love to get this machine working soon.
Images of the set up in the folder below.
 Thank you
« Last Edit: November 26, 2020, 12:37:34 PM by sean.crosbie »
Offline TPS
  •  2,627 2,627
Re: Best Way To Run My Machine
« Reply #1 on: November 27, 2020, 01:15:57 AM »
your controlbox has a cslab csmio/IP-M Controller. it is controlled via Ethernet
here: https://en.cs-lab.eu/technical-support/download/manuals-firmware-plugin/csmio-series-manuals-and-firmware-plugin/csmioip-m-user-manuals-download/
is a Manual witch Shows, how to connect the Controller to your Laptop. Win10 64bit should be ok.
