Looking for a 6axis+spindle breakout board for Mach3--Windows 10 Prefer US, but will use china, amazon?
I would like to send multiple signals to a relay. Example: 1 signal would =action A, 2 signals would =action B and so on. Is it possible to send a set of signals between gcode lines using the spindle output? Or can I send that same type of signal through an output port pin and get the same result. Basically a series of output signals on same line of code.
