Hello Guest it is March 14, 2025, 02:36:32 AM
Author Topic: Mach 3 gcode loads in, but wont start feeding co ordinates.  (Read 2575 times)
« on: November 30, 2020, 05:40:18 PM »
All of a sudden my Mach3 has quit working. It starts up, manual jogging movement works, and gcode loads in. But when starting the cut instead of the gcode co-ordinates feeding in line by line, it just stops at the very start.
What do you think the cause of this issue is?
Im using gcode that has been used before, and also tested other gcode I know has worked, and same thing.
Offline TPS
  •  2,558 2,558
Re: Mach 3 gcode loads in, but wont start feeding co ordinates.
« Reply #1 on: December 01, 2020, 04:30:12 AM »
can you pls post one of your files, and describe where (line) it stops?
