Hello Guest it is December 26, 2024, 03:28:11 PM
Poll
can you drive a stepper motor without a computer..
yes
4 (100%)
no
0 (0%)
Total Members Voted: 4
Author Topic: moveing z axis up and down  (Read 5868 times)
« on: October 05, 2007, 05:05:01 PM »
does anyone know about a stepper driver  , that will drive a stepper motor forward and reverse with out the use of a computer.   with a manual push button controller ,,:forward button and reverse button and speed.. simple and cheap...   to manual control my z axis..seperate from the computer driveing the x and y
Re: moveing z axis up and down
« Reply #1 on: October 06, 2007, 10:55:55 AM »
I think but not sure you could use a PLC
Offline Whacko
  •  239 239
  • Happy Days
« Reply #2 on: October 06, 2007, 02:17:05 PM »
Do you want to microstep? A simple step sequence can be implemented with a few components and no computer. "Elaborate", so I can "evaluate" what you want to do, then we take it from there!
Whacko for real
Nothing's impossible
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: October 06, 2007, 03:42:19 PM »
Hi, Brian
There are several boards that will do that for small steppers.
If you have a stepper control box you can use a 555 timer with a var. pot/resistor for puls/speed and control dir with 5 volt's.
Can you Fix LC  latest ver. Arc Errors ?.
Thanks, Chip
« Reply #4 on: October 07, 2007, 11:10:48 AM »
what about a gecko driver could this work?   has anyone done this before.   ,  the 555 timer sounds promising but sounds above my head.
Offline Chip
  •  2,055 2,055
« Reply #5 on: October 07, 2007, 07:16:25 PM »
Hi, Brian
What about a gecko driver could this work?,  Yes
Has anyone done this before ?, Yes, Used in several small stepper board kit's.
The 555 timer sounds promising but sounds above my head ?, Couldn't Happen !!
The timer board, 1 555 timer, 2 resistors 1 var. resistor 1 capacitor, 5 volts in, 5 volts puls out.
2, Push button switches N.O. DPST , UP Down.
All parts should be at Radio-Shack
Sent you a PM
Thanks, Chip
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #6 on: October 08, 2007, 06:31:44 AM »
Brian -
Since Art has done all the work for you, why do you want to build something seperate. All you need is a couple of push buttons connected on the input side of Mach3 and run a Macro. I assume your Z axis is already connected to a stepper (or you wouldn't need a stepper driver).
You can even do it without the push buttons by doing a Macro for the jog, and use the current jog buttons.
