Hello Guest it is June 22, 2026, 04:12:58 AM
Author Topic: Rotary help  (Read 9283 times)
Rotary help
« on: October 06, 2007, 08:49:58 PM »
  I'm trying to do  rotary  cuttings  but  I could not  go  one step ahead so far. First  of  all  my A axis is not working. I enabled A axis and  marked as  rotary .To see A axis movements   I edited a 2d tool path .I have  replaced  all  X  letters  with   A  .Then  I loaded and run the g code. All other axis works but  A axis does not move. Am I doing something wrong?      ???
Murat
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Rotary help
« Reply #1 on: October 06, 2007, 11:20:36 PM »
Hi, Murat
Hear's a xml and an A axis g-code file to try.
You'll need to change pin numbers for your stepper setup.
Hope this Helps, Chip
Re: Rotary help
« Reply #2 on: October 07, 2007, 03:45:21 PM »
thank you  works fine now.
Murat.
