Hello Guest it is December 26, 2024, 10:51:16 PM
Author Topic: Hercus PC 200 CNC lathe retrofit  (Read 6569 times)
« on: October 08, 2007, 06:48:31 PM »
We have a Hercus PC 200 CNC lathe that is not working, it loses home.  It has 8 position tool turret and uses servo motors with I believe Hewlet Packard HEDs encoders.  I would like to convert it to to run under mach 3.  Is it a good idea or leave it as is and have it repaired?
To have it repaired is a major pain in the neck as it is made in Australia, a traveling repair person goes across the U.S. and have to get on his schedule. :(
Mach 3 would be a much better interface. :)  Thanks!!
Re: Hercus PC 200 CNC lathe retrofit
« Reply #1 on: October 09, 2007, 09:27:28 AM »
It could be done.. you need to have a look at the servo drives from Gecko and CNCTeknix. Setting up the amps and wiring the machine is the hardest part of that project :(
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: October 24, 2007, 07:36:02 AM »
I have had some experience with PC200 yes you would be better off with a retro fit send me an email and we can chat
sapug_peter@internode.on.net
