Hello Guest it is December 26, 2024, 03:14:01 PM
Author Topic: Laser S commands with decimal???  (Read 1378 times)
« on: January 31, 2021, 04:08:16 PM »
Can Mach 3 read S commands for laser with a decimal? For example Does the S command need to me a whole number like S20, S25 S50 etc or can they have a decimal like S20.55 or S50.75 etc?
The reason I ask is I have purchased an app for laser raster that outputs S commands with a decimal point. Mach 3 doesn't seem to like this but I am not sure that is the issue.
Does anyone have any info that might help. The app author would likely be able to work with me on this if it needs to be changed but I thought I would do some research first.
Thank you for you help.
