Thanks yet again! I see that you access that via the Events tab of the main screen. The properties tab has the "PLC Interval" Does that mean that all PLC functions use that same interval? I was hoping to use 10msec for the racking detection. The interval property is currently set at 50. I am not sure if it would cause issues if I had all PLC scripts run at 10msec if I change that setting.
I hope others also benefit from this exchange as I feel a bit guilty asking you so many questions. One day I hope to start paying forward this help.
