Hello Guest it is December 21, 2024, 07:15:24 AM
Author Topic: Mach3, Opt Laser 5W and Aspire  (Read 28843 times)
Offline A11an
  •  62 62
Re: Mach3, Opt Laser 5W and Aspire
« Reply #60 on: February 24, 2021, 11:01:37 AM »
If I put the enable option back to 0 it works, not perfect but better than before see attached
Offline A11an
  •  62 62
« Reply #61 on: February 24, 2021, 11:10:26 AM »
Correction - sorry that's because it was in pin 2, I just tried it as advised by Opt Laser
Offline TPS
  •  2,536 2,536
« Reply #62 on: February 24, 2021, 11:22:41 AM »
step by step:
-put it back to mode 2, witch should enable laser beam by using input1
-MDI M3 S1000 -> beam should stay off
-measure with between GND and input1 (input1 disconnected)
-if you measure the 4.9v make link from Input 1 to  GND
Offline A11an
  •  62 62
« Reply #63 on: February 24, 2021, 11:42:56 AM »
I get 28mv thats it
Offline TPS
  •  2,536 2,536
« Reply #64 on: February 24, 2021, 12:25:27 PM »
this Manual (https://optlasersgrav.com/index.php?controller=attachment&id_attachment=56)
say's Mode 2 will enable Laser with Input 1 High
and on page 20/21 Hight Level is from 3-24V so for the Moment i have no answer why it's not
starting if you put 5V to terminal 3 (after M2 S1000)
maybe Manual is wrong.
Offline TPS
  •  2,536 2,536
« Reply #65 on: February 24, 2021, 12:28:34 PM »
pls check the voltage between Pin3 and 4 when the 5V are connected.
Offline A11an
  •  62 62
« Reply #66 on: February 24, 2021, 12:35:11 PM »
4.95v Between pin 3 & 4
Offline TPS
  •  2,536 2,536
« Reply #67 on: February 24, 2021, 12:36:23 PM »
but laser is not turning ON?
Mode2?
Offline A11an
  •  62 62
« Reply #68 on: February 24, 2021, 12:41:45 PM »
No
Offline TPS
  •  2,536 2,536
« Reply #69 on: February 24, 2021, 12:45:57 PM »
so maybe contacting
contact@optlasers.com
would be an Option, for the Moment i can't see, what we are doing wrong.
