Hello Guest it is February 05, 2025, 10:55:15 AM
Author Topic: help for repeatability with mach 4  (Read 2500 times)
« on: March 25, 2021, 03:30:42 PM »
I am turning cylinders with a diameter of 12 mm but each cylinder has a diameter that is always smaller than a tenth (12mm, 11.9mm, 11.8mm etc.) the offset of x moves instead ze 'perfect. why '?
Re: help for repeatability with mach 4
« Reply #1 on: March 26, 2021, 03:22:35 PM »
at a guess I would say that you have a conflict with your BoB and stepper drivers.
Lets say your stepper drivers are active low whereas you BoB has a pull-down resistor. In that circumstance
if your controller offered 20 steps CW followed by 20 steps CCW your steppers would advance 20 steps CW but
only 19 steps CCW.
« Reply #2 on: April 03, 2021, 03:47:55 PM »
hi thanks for the reply the settings are ok. the fault is the faulty motor driver.
