Hello Guest it is September 23, 2026, 11:34:40 AM
Author Topic: Can not Run from Here if the G-code lines is over 1000000 lines  (Read 19234 times)
Hello All,
I have some problem with mach3 software with license. I have the big files of G-code more than 1800000 lines.
 I have run with mach3 software  for a long time. After midnight, I will go to sleep. I stop the mach3 and remember the G-code line for  next running on tomorrow. the remembered line show 1075000 lines before stop. Tomorrow , I use Run From Here at the line at 1070000 but Mach3 show only begin at the line 1000000. Not 1070000. What happen ? I can not begin at the line 1070000. How to solve this problem ?
Offline ZASto
  •  434 434
Re: Can not Run from Here if the G-code lines is over 1000000 lines
« Reply #1 on: March 28, 2021, 07:37:37 AM »
For long operations I usually Feed Hold the machine, then press Stop, switch the spindle off and leave the rest switched on (Computer, drives, ...)
One of my files has a tad less of 1.6 million lines.
In the morning just switch on spindle and click Cycle Start :)
My personality is who I am.
« Reply #2 on: March 28, 2021, 09:26:50 AM »
็Hi Zasto ,
Thanks for your reply. I understood your meaning. But my problem is .... if run the G-code for long operations until the g-code number is over 1000000 lines. Assume the g-code number is 1251000 line with the feed hold. I hit the feed hold ,press stop and then go to Zero. Afterthat I need to use Run from Here on mach3 screen with the g-code number line at 1251000 or 1250000. The mach3 not allow to Run from Here at the begin line position at 1251000 or 1250000. The mach3 allow to begin only the g-code at the line 1000000 but I need to Run from Here at the begin line 1251000 or 1250000. How to solve this problem ? It waste time if begin at the line 1000000. Understand my idea ?
Offline ZASto
  •  434 434
« Reply #3 on: March 28, 2021, 10:53:16 AM »
If you don't switch your computer and controller off, there is no need to send machine to zero.
https://youtu.be/2gZfbM8A3qU
In this video you will notice that the run was resumed from line 1.7+ million.
« Reply #4 on: March 28, 2021, 11:42:44 AM »
Oh,Zasto
It seems your Run from Here is no problem.  I will show my problem to you later if I go to my factory.
Thanks for your help
Offline ZASto
  •  434 434
« Reply #5 on: March 28, 2021, 05:18:09 PM »
OK, video taken off, seen by one to whom is ment to be seen :)
