Hi All
Concluded after tests that the problem only exists when either the Feed Rates are to high
or the cutter motor is running.
The wiring for this DC Brush motor is quit separate from the stepper motors,
however the power supply is part of a multi-rail power supply.
Before I go and separate them totally, are there any settings that will improve immunity to motor noise ?
The speed is probably proportional to noise level at the wrong frequency, so slowing it down may resolve it.
However I need to totally eliminate the affect to gain confidence in the system.
Regards
