Hello Guest it is February 27, 2025, 08:38:56 PM
Author Topic: setting up 2 machines  (Read 4478 times)
Offline KRAM242
  •  8 8
  • CanNotCompute-CNC
« on: October 14, 2007, 12:19:11 PM »
Hello I was wondering if there is a way to have the settings in Mach, saved for my old machine and then I could use a A/B printer port switch to pick my new machine with new settings?
Thanks in advance
Mark
Mark
Re: setting up 2 machines
« Reply #1 on: October 14, 2007, 01:25:46 PM »
Just set up a profile for the new machine. If you start Mach from the Mach loader (Mach3.exe) you will see an option for a new profile, set this up with your new settings and name it appropriately. You can then start Mach from the loader and choose whichever profile you want.
  You could also a new shortcut so you could start by double clicking on the Icon you want. All you need to do is copy the original shortcut and then right click on it and go to properties, you will then see the target as C:\Mach3\Mach3.exe /p Mach3Turn or whatever your original profile is, then just change the last part to the name of your new profile.
Offline KRAM242
  •  8 8
  • CanNotCompute-CNC
« Reply #2 on: October 15, 2007, 07:26:52 AM »
Hey, thanks so much for the quick reply!.. Thats a big help.
Mark
Mark
