Hello
Guest
it is
October 01, 2026, 12:46:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Mach4 Plugins
Mach 4 XBOX360 controller plugin that doesn't require writing a LUA script ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 4 XBOX360 controller plugin that doesn't require writing a LUA script ? (Read 16152 times)
pmageau
19
on:
May 17, 2021, 08:19:28 AM »
Hey!
Is there a Mach4 plugin or product that *doesn't* require writing a LUA script ? It's fine if the plugin uses LUA and the user is free to edit later but it would be good if it also gives a default configuration to start with.
Anything ?
Logged
Bill_O
615
Re: Mach 4 XBOX360 controller plugin that doesn't require writing a LUA script ?
Reply #1 on:
May 25, 2021, 03:20:40 PM »
Many of the Plugins and standard products don't require a custom LUA script.
The scripting happens when you want something different or special.
The options and what people want are just too varied.
Logged
pmageau
19
Reply #2 on:
May 25, 2021, 03:38:12 PM »
Thanks Bill! I found that the xbox controller plugin doesn't need Lua coding for basic configuration. For some reason, when I tried to configure the controller before it popped up a Windows game Controller config. Then when I looked around for info, I saw people writing LUA code to get basic capability. I can code but I didn't want to have to
Logged
DavidSt
2
Reply #3 on:
July 17, 2021, 02:36:32 AM »
I've activated the Mach4 XBox360-Plugin.
Then I've tried to jog the the Xbox and nothing happend at the motors.
diagnostics looks like in the Pic:
the end of the String is "no Command". have the buttons not yet been assigned?
thanks in advance
David
Logged
rhtuttle
575
Reply #4 on:
July 21, 2021, 04:59:55 PM »
No, there are no defaults. Configure->Plugins->Xbox Controller
Not Configure->Control plugins tab
Logged
DavidSt
2
Reply #5 on:
July 22, 2021, 03:03:20 PM »
it works. thank you!
Logged
Print
Pages:
1
Go Up
« previous
next »
