Hello Guest it is October 04, 2026, 11:02:44 PM
Author Topic: Old VFD with USS Protocol and Rs485? need help  (Read 25408 times)
« on: August 01, 2021, 08:08:27 AM »
hi i have a old vfd from siemens.
it used a Protocol with the name USS.
it works over terminal via rs485 adapter.
but i want to use the vfd with mach3.
i use the vfd with pwm to 0-10V and 2 Relays.
first relay for start stop
second relay for left/right
works fine but is it possible to use the vfd via modbus or a plugin?
i attached the protocol pdf file
« Reply #1 on: August 03, 2021, 11:06:01 AM »
Hi i own a old VFD wich works via rs485
the Protocol is the USS Protocol from siemens.
is it possible to use the vfd with mach3 via rs485?
its not modbus!
thanks
