Hello Guest it is March 14, 2025, 03:25:13 AM
Author Topic: Part machines 180 deg out  (Read 18764 times)
« on: August 18, 2021, 03:43:41 AM »
Guys, I`m having an issue that i cannot resolve.
I  modeled everything in fusion 360. Coordinates are as shown.
Zero in Fusion 360 is set top right corner.
When i set that zero on the machine it treats that as "Left bottom corner" and machines away from the part.
If i set zero on the machine to left bottom corner, than the machine cuts 180 rotated part.
Any ideas?
Offline Graham Waterworth
  •  2,771 2,771
  • Yorkshire Dales, England
Re: Part machines 180 deg out
« Reply #1 on: August 22, 2021, 01:55:30 PM »
Your machine axis is reversed
« Reply #2 on: August 22, 2021, 03:04:27 PM »
your need to change "dirlowactive" in configuration. that will reverse the direction on the axis
« Reply #3 on: September 03, 2021, 11:08:04 AM »
Hi Guys.
Thanks for your reply. If I change "dirlowactive" then the jog is going the other way around. For example low arrow on the keyboard (say you want to Y-) sends the table away from me to Y+.
  •  9,284 9,284
« Reply #4 on: September 03, 2021, 12:59:05 PM »
The keyboard arrow keys relate to the direction of movement of the cutter over the workpiece so yes, the down arrow key would move the cutter to -Y on the workpiece and to do this the table would move away from you.
(You could, of course, always set-up a 'non-standard system' as in Config. / System Hotkeys Setup you can reverse the Scan Codes for the Y++ and Y-- Jog Hotkeys).
« Last Edit: September 03, 2021, 01:06:00 PM by Tweakie.CNC »
« Reply #5 on: September 03, 2021, 01:24:55 PM »
Ah, so it's all ok then. I've changed the hot keys to easy stock setup. All works now. Thanks
