Hello Guest it is December 26, 2024, 03:14:33 PM
Author Topic: mach 3 set up  (Read 15200 times)
mach 3 set up
« on: October 11, 2021, 01:11:38 AM »
I have a two tress 4 axis 100mhz board and it will not cut a circle  or let you jog two axis at the same time is there a setting in the program for this as each of my motor controllers has its own power supply? running nema34 with 48v 8amp power supply.
