Hello Guest it is December 22, 2024, 01:29:14 AM
Author Topic: Mach3 PWM stability under Windows  (Read 14641 times)
« on: November 19, 2021, 03:43:52 PM »
For those that have 'scoped the PWM signal, how much fluctuation was seen, either frequency or pulse width.
If so, at what set frequency?
Re: Mach3 PWM stability under Windows
« Reply #1 on: November 19, 2021, 06:19:30 PM »
PWM stability is pretty good if you use an external motion controller like an ESS, but not so good with a parallel port.
PWM is handled by dedicated hardware with an external motion controller whereas a parallel port is relying on a interrupt driven timer.
Windows makes extensive use of interrupts for its internal use and consequently interrupt driven timers fare poorly.
