Hello Guest it is January 15, 2025, 05:14:41 AM
Author Topic: HELP with Excel to Mach3  (Read 31608 times)
« on: November 29, 2021, 06:12:05 PM »
I need help with exporting excel data to Mach 3.
We manufacture windows and Doors and we use Mach 3 and an Aculite EconoCut Cutting table to cut glass sheets. we currently input manually all cutting sizes for each glass panel.
We use excel to create the work orders and to create a "cut list" so the operator can input manually all sizes.
But I'm trying to see if I can import the width and Height already in our excel data into Mach3, I'm able to export in .csv and .txt.
But can I use those formats to import the width and height into Mach3? I see that when the operator manually imports the measurements it creates a file .acu that the cutter machine uses to cut the glass sheets.
Can anyone give me some guidance?
Thank in advance
Martin
Re: HELP with Excel to Mach3
« Reply #1 on: November 29, 2021, 06:41:11 PM »
I have occasion to export data as a CSV file to Mach4, I've been using Mach4 for seven years.
I have written a script in Lua, Mach4's scripting language, that converts the input data stream to x,y,z triplets which then are incorporated
into the job.
I imagine you can do the same with CE, Mach3's scripting language, but I doubt NEARLY as easily as Lua.
Offline Graham Waterworth
  •  2,753 2,753
  • Yorkshire Dales, England
« Reply #2 on: November 29, 2021, 07:57:57 PM »
You could write an excel macro to create the G-Code.
All you need is a basic script to insert the values that change.
This video may help
https://www.youtube.com/watch?v=bY7w4YJNyhw
« Last Edit: November 29, 2021, 08:07:39 PM by Graham Waterworth »
« Reply #3 on: November 29, 2021, 08:58:01 PM »
This video may help
Thank you guys for your help, I'm completely lost but that video helped a lot figuring out the structure of the content in the file, as far as the file format that would be readable by Mach3. What file format should I use for output?
I have a macro that outputs a .csv file, but I can also make it output it to .txt file
This is what file looks like this when I open it in notepad. Im still working on making the decimals show as xx.xx
WIDTH,HEIGHT
12.25,54
6,32
22,34.25
28.5,21.8125
38,86.8125
21.1875,75.8125
9.125,83.8125
I hope Mach3 can take those two measurements an is able to make the cuts on the table cutter.
« Reply #4 on: November 29, 2021, 10:09:14 PM »
Mach3, in fact just about ALL CNC software requires Gcode, it is by far and away the most common mode of translating coordinates to machine
motion.
Search Google for Gcode.....enjoy.
« Reply #5 on: December 02, 2021, 11:13:16 AM »
Here you go.  One row from a simple spreadsheet that does the conversion - see attached file.
WIDTH   HEIGHT   g-code
12.25   54          G01 X12.25 Y54
The secret sauce is this Excel formula:
="G01 X"&A3&" Y"&B3
Where A3 and B3 contain the width and height values starting at row 3 for the first set of values.  So you just put your list of dimensions in columns A and B, put the formula in cell C3, and copy it down for as many rows as you need.
To get the table of dimensions into Excel get it exported as a csv file and open it in Excel - you probably know that.  Then paste the values into the above spreadsheet to do the g-code conversion.  To output a file to drive Mach3, copy the column with the g-code in it and paste into a new blank .txt document and save (or if on the same computer just open the "edit g-code" Mach3 window and paste it in).
I've used this method a lot to generate g-code for lots of odd shapes that need to be generated from mathematical formulae and it works just fine.
« Last Edit: December 02, 2021, 11:16:27 AM by JohnHaine »
« Reply #6 on: December 02, 2021, 11:15:50 AM »
Just a note to the powers that run this site - it doesn't allow xlsx file extensions!!  Since Excel started using these in 2003 I think the site needs to catch up!!
« Reply #7 on: December 12, 2021, 04:01:41 AM »
Why do we bother to try to help people when they can't even say thanks?
  •  2,753 2,753
« Reply #8 on: December 12, 2021, 02:48:35 PM »
I have been doing this over 16 years and in that time I have learned some people are very greatful for the help but in general most want a quick fix with the minimum of effort.  That is why I limit what I do for people now.
« Reply #9 on: January 01, 2022, 07:02:08 PM »
Ok got it to work after may tries, thank you so much for your help.
I'm a newbie and it took me a while to understand G-code, and having no support form the machine manufacturer it took me a while linking the data and understand how it works from Gcode to the glass cutter. The hardest part was understanding the machine uses XY coordinates to make the cut and not actual numbers.
But your code worked perfectly once I understood how it works.
Please DM your PayPal SO I can buy you some coffee or beer.
Thx
