My 1st Posting!
I am confused about settingup my limit and Homing switches. As you can see in the below drawing each axis has two normally closed switches, one just a limit and the other is both a limit and home switch both switches are wired in series. The breakout board manufacture showed this thpe of switch configuration and I understand that this is possible, I just can't find the way to set it up. The X axis is connected to pin 10 on the breakout board. Mach3 must have a way of knowing the direction it is travling and if it hits a limit or a limit and home switch. The breakout board has Gnd, 10, 11, 12, 13, and 15 for the limits, home and EStop switches.
How do you configure this? Also If a limit is hit I want to drive off of it automatically, to get out of theh error condition.
I also pasted a the input screen where I think this is done, but don't know how. Please refer to tabs and screens in their exact names, so I can see how to do the setup. Remember this is my first post.
