Hello Guest it is October 02, 2026, 10:28:10 AM
Author Topic: Fine Tuning Stepper Motors  (Read 24038 times)
Offline kolias
  •  1,165 1,165
« on: July 02, 2022, 04:51:29 AM »
Got all limits/homing working and now I want to fine tune the 4 stepper motors which are all working fine but I find the jogging kind of rough.
Using the stepper calculator which I got from this forum I come up with a result of 16000 steps per inch which is a high number. If I remember correctly the number I used before was about 4000 steps per inch but I have lost the calcs.
My screws are 16mm diameter with10mm lead and single start. Motors are NEMA23, 270oz/in, 2.8A, Step angle 1.8 degrees, I use 8 microsteps and the motors are direct coupled.
What my steps per inch should be?
Nicolas
Re: Fine Tuning Stepper Motors
« Reply #1 on: July 02, 2022, 06:05:31 AM »
 OK so with the calculator I have and with the info you have given I get 160 steps per mm and if you multiply that by 25.4
You get 4064 steps per in. does this sound about right?
Regards
Charlie M.
Offline kolias
  •  1,165 1,165
« Reply #2 on: July 02, 2022, 08:28:26 AM »
Thank you Charlie, that sound correct to me.
Are you familiar with an Excel spread sheet which was created by a member on this forum and it calculates the steps. Its very easy to use but I get as I said a high number and I was wondering why.
For now I will use 4064
Many thanks
Nicolas
« Reply #3 on: July 02, 2022, 08:34:55 AM »
 It might be the one I was using. I don't remember where I got it from. that will get you close and then you can use the axis calibration in Mach3 to get them spot on. Happy 4th.
Regards
Charlie M.
« Reply #4 on: July 03, 2022, 11:46:31 PM »
with a 8 microstep per fullstep regime your stepper will require 1600 pulses to do one revolution. If the pitch of the screw is 10mm then:
1600 / 10 =160 steps per mm or 4064 steps per inch.
If the numbers you have supplied are correct this should be perfect, no further tuning or messing around required.
