Hello Guest it is December 26, 2024, 09:50:12 AM
Author Topic: Limits Override Problem  (Read 36954 times)
Offline kolias
  •  1,163 1,163
Re: Limits Override Problem
« Reply #20 on: July 18, 2022, 02:39:09 PM »
Some new developments……..
Started the cnc this morning and decided to follow some previous instructions I had regarding the Mach3 main screen buttons “Machine Coord’s and Soft Limits”. Finally I got all the DRO’s to zero and I believe my previous problem (not been able to jog out of the X axis) may be related to my original machine state (where all axis are located).
After the above I decided to Ref the Z axis which I never done. This went smooth like the Y&A before, it hit the top limit and stopped the axis and I was able to backout.
Then I tried again the X axis which before I could not backout. Well this time I was able to backout and I don’t know why.
Then I tried again the Y&A BUT this time each axis went in the opposite direction and I stop immediately (the Y went towards the back and A towards the front). I verified that the A was slaved to Y and then checked the Home/Soft limits and the A was NOT ticked so I did ticked the A and now they both run in the same direction.
My questions:
Should the A be enabled in the Home/Soft limits screen? (My previous notes say if the A is slaved to Y I should only tick the A).
When I reference an axis in the diagnostic screen after its done should the numbers under the column “Current Position” be set to +0.0000? (mine I see no zeros, just +numbers and I think this is wrong)
In the main Mach3 screen and under the DRO there are 2 buttons. Machine Coord’s and Soft Limits. Under normal operation like now I’m setting my Home positions does it matter which button is pressed? Or non should be pressed?
Nicolas
« Reply #21 on: July 19, 2022, 05:16:23 AM »
Answer is Yes. you may have to reverse A so it wont rack the gantry.
If you have the machine coordinates button activated.
If homing while in machine coordinates DROs will set to zero and everything will be ok.
I would not worry about the soft limits button. if you have switches then soft limits are optional.
hope this helps.
Regards
Charlie M.
