Hello Guest it is September 11, 2026, 04:39:30 PM
Author Topic: PWM Spindle Speed off by a factor of 100  (Read 25812 times)
« on: September 06, 2022, 07:37:53 PM »
I just purchased a LMS 3990 mini mil that’s had a CNC conversion done using an ESS board, MX3660 stepper driver, and a LMS 4213 CNC spindle speed controller. The issue I have is that regardless of the Spindle RPM I set in mach 3, my machine is at full speed until I set it below ~15rpm. If I set the RPM between 0-15 the spindle speed changes, almost as is the PWM signal is off by a factor 100 or 200. Any ideas?
Re: PWM Spindle Speed off by a factor of 100
« Reply #1 on: September 07, 2022, 12:36:45 AM »
What are your M3 config settings on the PWM output?  I can't see any recommendations in the 4213 instructions.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #2 on: September 08, 2022, 05:56:38 PM »
Have you set the min and max values in the spindle pulley section and selected pulley 1
« Reply #3 on: September 08, 2022, 08:34:13 PM »
Sorry for the late response everyone. I have attached screenshots of my settings. Yesterday I measured the voltage coming from the Leadshine to the mill, when I set the RPM to 3 in Mach3 the signal voltage was about 1v, 15rpm was 6v, 20rpm was 8v, and 25rpm was 10v. Any RPM I set between 25-2500 was still reading 10v. Very weird, definitely some variable a couple decimal places off somewhere.
« Reply #4 on: September 09, 2022, 02:43:14 AM »
Your pwm base frequency is very low at 5hz.  Try increasing it to 100.
  •  2,785 2,785
« Reply #5 on: September 14, 2022, 11:21:25 AM »
Have you set your pulley speeds
