Does the Galil Plugin reset the PID values?
I tuned my servos using the WSDK, which stores the PID values on the card (I don't think it's an actual "burn") when it's done. If I exit the WSDK, and run in again, the PID values that are shown before I run any tests are the same as before. No change = "good". It's always been "set and forget" before this.
If I run Mach3 + Galil plugin, then exit, not even run a job, then run WSDK or DMCTerminal program to query the PID values... they are reset back to the system default. Changed PID values = "bad", "very bad".
It appears that Galil plugin is doing some kind of reset or master reset of the card? A regular reset shouldn't cause a problem because the values are supposed to be stored in flash memory.
--Scott
