Hello Guest it is July 27, 2024, 09:25:15 AM
Author Topic: BAD CHARECTER USED LINE 0  (Read 10567 times)
« on: January 19, 2023, 12:35:58 PM »
Hello, sorry new to cnc  using Mach 3 trying to run g code program. Keep coming up with this status. How do I fix it so I can run program. Thanks for your help.
Re: BAD CHARECTER USED LINE 0
« Reply #1 on: January 19, 2023, 01:34:53 PM »
Can't possibly say unless we can see the code.
Offline ZASto
  •  424 424
« Reply #2 on: January 20, 2023, 03:34:02 AM »
Reinstall Mach (keep your license and configuration files).
My personality is who I am.
« Reply #3 on: January 20, 2023, 06:40:49 AM »
Can you jog the axes?  If so then Mach3 is probably working OK and you shouldn't need to re-install.
The G-code interpreter expects to see and recognise a limited range of characters, except in any comments section of a line (a "block" in g-code speak.  If you have any other character you would probably get an error like the one you see.  It could even be a non-printing character.  That's why I suggest you post the code so we can see if there is a problem.
If there isn't a spurious character then re-install.
Offline ZASto
  •  424 424
« Reply #4 on: January 20, 2023, 09:31:23 AM »
John, I had that kind of problem, that's why I recommended installation of Mach3.
Ordinary ASCII G-code file got misinterpreted for unknown reason :(
Reinstall solved the problem.
« Reply #5 on: January 20, 2023, 09:49:41 AM »
Aha!
